99 Accord seems to be starving for fuel
Old Aug 28, 2010 | 09:26 PM
merc1100sc's Avatar
Default 99 Accord seems to be starving for fuel
Hello all. I have a 99 Accord LX Couple 4cyl w/ 140K miles.
The other day it stumbled and bucked from a stop light.
As soon as I get rolling in 1st gear it bucks, get the rpm's up and it's ok, shift into 2nd it bucks, get the r's up its ok. etc.
today it starts and stumbles at idle. I try to drive it and it dies.
tonight i tried to troubleshoot it. I can hear the pump runnign when the ignition is turned on. I pull the feed line from the pump and fuel seems to be pumping fine when the key is turned on and while cranking but it will not start. makes me think its a clogged fuel filter or pump going bad, but everytime I check, there is fuel pumping.
Any suggestions?
Thanks.
Old Aug 29, 2010 | 02:57 AM
deserthonda's Avatar
..you can have fuel pumping but it might not be sufficient volume .chk fuel pressure ,hook up a fuel pressure gauge ......How long has this issue been happening ?? when was last time you filled gas tank??
you can remove the fuel pump and visually chk the filter ( pick up screen ) at the bottom of fuel pump,
Old Aug 29, 2010 | 07:11 AM
merc1100sc's Avatar
It started this past Friday. I havent filled the tank in quite some time.
I will check the filter first.
I have also heard of the main fuel pump/injection relay under the dash going bad causing this problem.
Can anyone verify this?
Thanks
Old Aug 30, 2010 | 04:22 PM
Doesn't sound like main relay because then the pump wouldn't run. And the engine wouldn't start at all.
richybaby
Dec 8, 2010 05:25 PM
MA93Accord
Nov 3, 2008 08:03 AM
1995capricewagon
Dec 1, 2007 03:56 PM
europeanboy
Aug 7, 2007 04:33 PM
mbo1985
13
Apr 23, 2006 01:39 PM
