99 honda accord high idle after timing belt change
Old Jan 3, 2013 | 09:45 AM
mike186abl's Avatar
Default 99 honda accord high idle after timing belt change
hi guys i just did a timing belt water pump seals the whole nine yards on a honda accord and i just finished it off and started the car up after topping off the fluids and when i started it up it had a really high idle like 5000 rpm so i shut the engine off ASAP what went wrong. 4 cylinder 2.3 vtec 5 speed
Old Jan 3, 2013 | 10:18 AM
Really HUGE vacuum leak: or maybe the throttle cable is hanging up holding the throttle open?
Old Mar 22, 2023 | 09:24 AM
kawboy636's Avatar
This is an old thread and a long shot that anyone will see this. I have the same exact problem with the same vehicle - 1999 Accord LX 2.3 a/t. I changed the timing belt, tensioners, water pump, and drive belts. When I start the car it immediately revs up over 4K. I have to shut it down right away. I bled the coolant and checked the vacuum lines. Did you ever solve the problem when you experienced it?
mike186abl
Jan 3, 2013 12:01 PM
newyota
Jul 11, 2011 03:40 PM
KincaidChance
May 3, 2011 01:13 AM
richybaby
Dec 8, 2010 05:25 PM
FlyLow
Jun 22, 2006 10:09 AM
