99 temp gauge flactuating
Old May 10, 2011 | 01:28 PM
Greendevil511's Avatar
Angry 99 temp gauge flactuating
99 accord i4 vtech, had a tranny put in and clutch, replaced temp sensor (not the one by thermostat) replaced coolent sending unit, replaced thermostat, performed coolant flush and bleed the system several times , replaced cap and rotor, cleaned iacv , and cleaned the throttle body. When starting cold the temp gauge reads fine let it idle to warm up to proper temp its fine. when i drive it for couple miles temp gauge goes up almost to hot. While in motion it will read high but when i start to slow down the temp gauge goes back down to normal about half way. Do i have a bad temp sensor or what i don't have a scanner that i can read data-stream of off does someone have any suggestions or know what to do?
Old May 11, 2011 | 06:30 AM
Honda4me's Avatar
does the fan operate?
I know you said that you bleeded the system to get the air out, may still be some air left? I say this because on my other car, (Mitsubishi Pajero 4x4 TD) it can be a nightmare to get all air out, and if not properly out, can lead to several other problems. Just an idea.
Old May 11, 2011 | 09:40 AM
the fan does kick on but it takes a while, if i turn the ac on both the fans work so i doubt its anything to do with the fans... ill try to bleed the system again but its just weird that it would go down when I'm coming to a stop the temp doesn't change that fast....
Old May 11, 2011 | 07:44 PM
Be sure that the heater control valve is open when bleeding the system....
pirulino23
Nov 10, 2010 06:18 PM
raf105
Sep 28, 2007 02:55 PM
corr04
Jun 7, 2006 01:24 AM
honker3
Dec 6, 2005 08:33 PM
fperezal
Sep 29, 2005 09:29 PM
