9th Generation Accord with Direct Injection (DI) Engine
Hi Folks... I was wondering if any forum members have experienced other engine issues with the 9th generation direct injection engine. I am considering buying a used 2014 Accord with the 2.4 liter engine next year and I would like feedback on this. -- Part of the reason for this post is that Consumer Reports mentioned in their Feb. 2015 issue that "over time DI can lead to clogged fuel systems and engine carbon buildup." The magazine mentioned that other manufacturers (BMW, Kia) have put out technical service bulletins regarding their DI engines implying that many of these newer engine are more problematic than non-DI engines. Just wondering if this magazine is exaggerating the situation or not. - Thanks
I moved this to a new thread as your question didn't seem to fit at the end of the thread it was in.
Can an Atkinson engine be direct-injected?
As in the heading, can an Atkinson-Cycle engine be direct injected, or by design is DI ruled out? More specifically, is the engine in the 2017 Accord Hybrid direct-injected? I see a looming monster of an issue across the industry regarding DI engines, i.e. intake valve deposit build-up. Sure, it can be negated to some extent, but not completely. So, seriously considering the purchase of the Accord Hybrid, non-DI being one of the primary factors.
No response at all? YES, DI engines are problematic regarding deposit buildup on the intake valves. Just ask Audi/VW, as they seem to be having the worst struggle. A "Catch Can" may be a possible solution to slowing down the deposits, but it is going to happen nevertheless. I would predict that turbo engines will suffer the most, with higher pressures resulting in increased crankcase gases through the PCV system, the primary source of these deposits. The only real solution will be periodic cleaning of the intake valves, typically with a walnut-shell blaster. However, if one has an engine with the intake manifold located to the rear (firewall) side, then pulling the head will be necessary.
any more word on this?
I see you bought it, did you get the answer you wanted or are you just risking it? |
Originally Posted by veggieluva
(Post 376229)
