ABS Light
Old Dec 2, 2010 | 07:12 PM
george 66's Avatar
Default ABS Light
1995 ACCORD EX ABS light on most times (sometimes not!). Tried to bleed system - no good. Had codes read, and result is '18'.
Any help on what to do?
Old Dec 3, 2010 | 01:00 PM
jeffk14's Avatar
A little Google Foo:
http://www.google.com/search?client=...=Google+Search
Lots of info on the first hit.
Old Dec 3, 2010 | 05:12 PM
I have not troubleshooted ABS systems too much. Was the brake fluid level low?
A code 1-8 is for the high pressure system.
Possible causes: Accumulator gas leakage, Charged relief valve set pressure, Rear outlet solenoid valve late to close, charged pressure switch set pressure.
I would take a look at the 94 shop manual that you can download from the Online Manuals thread in the DIY section. It shows the diagnostics for that ABS code. At the end of the diagnostic tree it says to replace the modulator.
You could try replacing the o-ring on the accumulator. It is #23 on the diagram below. And costs less than $2. Maybe someone on here can give you tip on how to properly remove the accumulator from the abs unit. That accumulator builds up pressure, so you have to take to proper precautions to remove that component.
Old Dec 3, 2010 | 05:22 PM
Good advice from PAHonda.
Only thing I would add is that used modulators can be readily found w/ car-part.com and looking near your zip code. I've purchased this unit for <$50. Make sure you get a 30-day warranty for a dud part.
Easy removal/installation, but requires a 10-mm flare tubing wrench to avoid rounding those very tight tubing nuts.
93Accord2.2
Nov 7, 2013 07:10 AM
brayner
Feb 12, 2013 06:59 PM
mickey4live
Jul 6, 2012 08:29 AM
anthonyj89
Sep 24, 2008 10:20 PM
shinobi16
May 18, 2005 08:21 AM
