ABS Light
Long story short...I bought a 1994 honda accord, the ABS light was on. I unplugged the ABS computer and figured that I would come back to it later...well it's later. I know you can pull codes, but as soon as I restart the car the ABS light is off (would there still be any codes). What I did was raise each tire and spun them...the only one that tripped the ABS light was the driver rear...so I think that sensor is bad...going to pick n pull in the morning to get one. I can't remember where I read that you are able to check the wheel sensors this way...might have been here..if so and this works thanks to who ever posted.
I'm not sure what they are...the code or what to look for I mean 4 long/short blinks and bink blink lol is there a chart? I want sure if it was kept im memory. No light untill I start moving...only the driver wear trips light when spinning them individually...kinda thought it was a "short cut" check
I know google and find em
94-97 ABS CODES
You pull these codes the same way you pull check-engine codes, but it's the ABS light that's blinking. Here's the sequence...
Insert the jumper, then turn on the key.
Long (2sec.) flash - long (2sec.) pause - this isn't the code yet.
Short flashes for the first digit of the code - 1sec. pause - short flashes for the 2nd digit.
Long (5-second) pause, then the next code.
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
There's NO long flashes, it's all short flashes with short & long pauses in between.
Beginning in '98 there's a whole different ABS system, with a different list of codes.
... courtesy of g22cd5 over in the DIY section, who nabbed them from one of my long-ago posts at Honda-Tech.
(94-97) ABS DTCs...
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
In the Common DIY Threads there is a link to a manual you can download----a 4 2 is left frt, a 4 8 is left rear?
Pull the connector and measure the resistance to the sensor? What reading do you get (700~1,000)?
Thanks you guys. This is next weeks project
. Going to clean the EGR tomorrow. When I first got the car I cleaned all the sensors...was reading somewhere about cleaning the inside were the sensor sits in the hub...going to try that first (after pulling the codes
Picked up another wheel sensor...pulling same code : 4 4 wheel sensor RR
Is there a way to test the wheel sensor...I mean resistance or something.
Going to check the resistance tomorrow morning
Last edited by brianwindorski; Oct 17, 2011 at 08:27 PM. Reason: Didnt read the above post about checking resistance.. :(
