ABS Light
Old Oct 13, 2011 | 04:04 PM
brianwindorski's Avatar
Default ABS Light
Long story short...I bought a 1994 honda accord, the ABS light was on. I unplugged the ABS computer and figured that I would come back to it later...well it's later. I know you can pull codes, but as soon as I restart the car the ABS light is off (would there still be any codes). What I did was raise each tire and spun them...the only one that tripped the ABS light was the driver rear...so I think that sensor is bad...going to pick n pull in the morning to get one. I can't remember where I read that you are able to check the wheel sensors this way...might have been here..if so and this works thanks to who ever posted.
Old Oct 13, 2011 | 05:33 PM
Well keep us posted.....If you tripped the light, why not get the codes? Also take a volt meter with you so you can test the one you pull....or test the one on the car.
Old Oct 13, 2011 | 05:42 PM
I'm not sure what they are...the code or what to look for I mean 4 long/short blinks and bink blink lol is there a chart? I want sure if it was kept im memory. No light untill I start moving...only the driver wear trips light when spinning them individually...kinda thought it was a "short cut" check I know google and find em
Old Oct 13, 2011 | 08:56 PM
94-97 ABS CODES
You pull these codes the same way you pull check-engine codes, but it's the ABS light that's blinking. Here's the sequence...
Insert the jumper, then turn on the key.
Long (2sec.) flash - long (2sec.) pause - this isn't the code yet.
Short flashes for the first digit of the code - 1sec. pause - short flashes for the 2nd digit.
Long (5-second) pause, then the next code.
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
There's NO long flashes, it's all short flashes with short & long pauses in between.
Beginning in '98 there's a whole different ABS system, with a different list of codes.
... courtesy of g22cd5 over in the DIY section, who nabbed them from one of my long-ago posts at Honda-Tech.
In the Common DIY Threads there is a link to a manual you can download----a 4 2 is left frt, a 4 8 is left rear?
Pull the connector and measure the resistance to the sensor? What reading do you get (700~1,000)?
Old Oct 13, 2011 | 09:48 PM
Thanks you guys. This is next weeks project . Going to clean the EGR tomorrow. When I first got the car I cleaned all the sensors...was reading somewhere about cleaning the inside were the sensor sits in the hub...going to try that first (after pulling the codes ).
Old Oct 14, 2011 | 09:54 AM
well cleaned the EGR ports...wow every port was packed/plugged...pretty ugly...
Old Oct 17, 2011 | 05:38 PM
Picked up another wheel sensor...pulling same code : 4 4 wheel sensor RR
Is there a way to test the wheel sensor...I mean resistance or something.
Going to check the resistance tomorrow morning
Last edited by brianwindorski; Oct 17, 2011 at 08:27 PM. Reason: Didnt read the above post about checking resistance.. :(
Old Oct 18, 2011 | 02:43 PM
Checked the speed sensor, I have 0 resistance and no continuity. Am I supose to have 700~1,000 ?
Old Oct 18, 2011 | 02:51 PM
Sorry, for the rear it is 600~900 (resistance)....I posted the measurement for the front earlier.
