AC compressor connector
Old Jul 17, 2014 | 01:20 PM
zef's Avatar
zef
Default AC compressor connector
Car model: 2001 Honda Accord EX V6
The AC in my car is not working because the connector from the compressor to the engine is broken. The connector (highlighted in image) connects the green wire with the black wire. Both the connectors are broken (male and female).
Can you suggest how to fix it? I have been trying to find this connector but no luck. The repair shop is quoting $100 for fixing it!
Is there a part number for the connector? Where can I find it? Is it necessary to have this connector or can I just attach those two wires directly?
Any help is much appreciated!
Thanks.
Old Jul 17, 2014 | 01:42 PM
The connector is not sold separately. If you want the identical connector, best bet is a salvage yard. They may not sell just the compressor side connector if the compressor is still good.
Of course you can connect the wires directly. You can use any type of matching male and female connectors if you wanted to be able to connect and disconnect quickly. A single butt connector would work too.
Old Jul 17, 2014 | 01:55 PM
The Honda electrical circuit diagram only show a gray 1P wire connector for the compressor. On the female OEM compressor side, it should be a Lt Blu wire. On the male harness connector side, it should be a red power wire.
Ground is from the base of the compressor.
Old Jul 17, 2014 | 02:06 PM
djkurious's Avatar
Like redbull-1 said, if you want crimp the wires together and tape. If I can recall, its more of a connector because the compressor may need to be removed/replaced.
Old Jul 17, 2014 | 02:15 PM
zef's Avatar
zef
redbull-1: I bought the car used, so it is possible the wires are not OEM, and therefore different colors than the electrical diagram you mentioned.
Thanks to both of you for prompt responses.
On a related note, if I crimp and tape the wires, how can I confirm that it is working? Freon is low so the compressor might not start. I need the connection to be able to fill up the freon.
Old Jul 17, 2014 | 02:24 PM
If refrigerant level is adequate, the hi/lo pressure switch will close enabling the compressor. You can check the hi/lo pressure switch contacts for continuity (adequate pressure) or if open, the pressure is too low to enable compressor.
AC hi/lo pressure switch appears to be on the receiver/drier in front of the condensor, pax side.
The refrigerant pressure in a new can is adequate to create enough charge (heat w/ hot water to improve charging) to enable the compressor briefly and continue the charge. No need to jumper the AC relay.
If refrigerant level is zero pressure, you should start by replacing receiver/drier (contaminated w/ moisture from atmosphere) and vacuuming before charging into vacuum.
Old Jul 21, 2014 | 01:04 PM
R.A.D.'s Avatar
I just replaced the compressor on my car and the new Denso had a different shaped plug than the existing one so I had to snip the plug off and direct wired it. I have the connector you are looking for with approx. 6" of pigtail coming off of it. You can have it if I can find it. I know I didn't toss it but exactly where I put it is the question. I'll look for it today and post back when I put my hands on it and have it ready to mail to you.
Steve
Old Jul 21, 2014 | 01:10 PM
zef's Avatar
zef
Thanks to all the help and recommendations. I was able to disconnect the broken connector and crimp the wires together over the weekend. Refilled the Freon and have a working AC!
Steve,
Thanks for the offer, but I already snipped the wire and direct wired it.
Old Jul 21, 2014 | 02:08 PM
R.A.D.'s Avatar
No worries mate. Glad you got her fixed. Stay frosty!
basket_case
May 10, 2015 06:06 PM
ak474u
May 4, 2015 11:15 PM
seattle_bryan@yahoo.com
Jul 9, 2011 01:40 PM
Ruppe
Aug 9, 2006 10:59 PM
TechnoGecko
Jun 29, 2006 03:52 PM
