ac diagnoses step by step
Old Jul 24, 2008 | 01:34 PM
maro's Avatar
Default ac diagnoses step by step
Please explain to me like an infant. AC never worked. I want to fix it. Where do I begin?
Old Jul 24, 2008 | 02:53 PM
Default RE: ac diagnoses step by step
More information for us.
Are you comfortable with electrical troubleshooting & repair? Thats the place to start.
Working with the refrigerant system means buying some expensive equipment. More practical to fix (or rule out) electrical problems then take it to a shop.
How do you want to do this? Theres a few people on here that are much better than me with the refrigerant side of things.
Old Jul 24, 2008 | 03:01 PM
falkore24's Avatar
Check that the fan and compressor clutch work first.
falkore24's Avatar
I had a better post, but it got the HAF error.
Old Jul 24, 2008 | 03:17 PM
maro's Avatar
I would just be searching old threads if it would work. How do I test the clutch? and I'm not expert at electric, but I can give it a shot (shock)!
Old Jul 24, 2008 | 03:22 PM
falkore24's Avatar
Have someone sit in the car and turn the AC on and off, you should see the pulley engage and disengage the compressor. With the car and AC on, both fans should spin.
Old Jul 24, 2008 | 03:58 PM
maro's Avatar
okay, I'll give it a shot in about an hour. If the clutch does not engage, what is it then a matter of?
Old Jul 24, 2008 | 04:38 PM
falkore24's Avatar
bad clutch or controls
Old Jul 24, 2008 | 05:05 PM
Other possibilities...
Refrigerant leaked out = pressure switch prevents the compressor from switching on. In that case you need to find& fix the leak.
Electrical problem = lots of possible places. Bad relay, bad switch, loose wiring, etc, etc...
Old Jul 25, 2008 | 11:04 AM
maro's Avatar
okay,
I didn't start diagnosing the ac yet.. gonna start tomorrow, had to take her in this morning for rotors and brakes.
I'll be on here asking quetions this week-end for sure. Thanks guys
