AC Help Needed
Old Jul 25, 2011 | 06:34 PM
Something is up with the clutch of the compressor. The gap could be too large. The clutch magnetic coil could be bad. The ground on the compressor may need cleaning.
That Philips head bolt can be removed and you can clean that ground wire. See red arrow in pic.
Then test the resistance the clutch coil. See attached pic. Those are the easiest items to try first.
Old Jul 27, 2011 | 07:32 PM
dalejamin's Avatar
Default Update
Didn't see the last post until after I changed out the compressor. No change with the replacement compressor. The compressor won't engage even with pressure switch jumpered. Also, now both fans run for engine cooling (with or without the AC switch on), but neither run when I press the AC switch. I'm wondering if it's a wiring issue. I'm at a complete and total loss, as usual
Old Jul 27, 2011 | 08:06 PM
Something strange is going on with your car.
First of all, when you changed the compressor, how did you refill the system, since the compressor isn't working? Did you pull a vacuum on the system?
Old Jul 27, 2011 | 08:08 PM
dalejamin's Avatar
Haven't charged it yet. My dad has a vacuum pump I planned to use this weekend to do it. I just wanted to see if the compressor would engage, so I jumpered the pressure switch.
Old Jul 27, 2011 | 08:23 PM
Air doesn't really compress like R134a does, so don't try that test again.
I would unplug the compressor just to be safe. You can jump that pressure switch and recheck that you have 12V going to the compressor electrical connector.
Once the compressor is under vacuum, then you can try to see if it engages.
Old Jul 27, 2011 | 08:41 PM
dalejamin's Avatar
I really appreciate the advice. I'll put a vacuum on the system this weekend and check it out. I'll also double check the voltage at the compressor and post what I find. Thanks again!
Old Jul 28, 2011 | 06:37 PM
  #17
Originally Posted by dalejamin
I confirmed voltage at the compressor and carefully rapped on the clutch face, with no luck. Bad compressor?
What was this reading?
Was the new compressor grounded? If you just put the wire on and grounded it (no belt on the compressor) just to see if the gap closed you should be fine.....no turning the compressor isn't "compressing" anything
mamtsberg
Mar 17, 2010 09:15 PM
csweet
May 20, 2006 02:09 AM
45auto
Apr 10, 2006 05:06 PM
Taggart
Feb 15, 2006 12:35 AM
calenatar
Feb 14, 2006 06:36 PM
