accord 2003 heated seat lights.
Old Dec 29, 2007 | 05:39 PM
jimbowk
Default accord 2003 heated seat lights.
The radio display lights quit so I took it to the honda garage. they fixed it under the radio warrenty. The next morning I noticed the lights on both seat warmer switches only when on high don't work. the seat still gets warm but the light does not work. It works on low, just not on high. The garage says they did nothing wrong, the light bulbs must have both burned out at the same time.
My Question is, Is this possible, or does the wireing go through where they were working. I don't know how much they had to tear out to fix the radio.
thanks.
jim
Old Dec 30, 2007 | 12:30 AM
Chiovnidca's Avatar
Default RE: accord 2003 heated seat lights.
Put some bulbs in it.
Old Dec 30, 2007 | 01:01 AM
HondatechAV6's Avatar
the bulbs burnt out. but we remove that part and it snaps back in place, the shock helps shorten the bulbs life.
Old Dec 30, 2007 | 07:18 AM
jimbowk
there are two seperate switches. Both burned out at same time?, It's not the easiest to get too. I took one switch apart about half way. Does the housing have to come off to get to the bulbs or, there are 3 turn in dials in the side of them. I pulled out center one. It looked like the bulb. One bulb only. when on low it works. not on high.
What are the other two dials?
Old Dec 30, 2007 | 12:23 PM
the 'dials' are the bulbs. i believe there are 2 blue and 1 brown colored sockets? i forgot. either way, the two side bulbs are the amber light when you activate the seat heater on high or low, and the center bulb is the illumination when you turn the headlights on.
Old Dec 30, 2007 | 12:26 PM
jimbowk
thank you very much for the help. I'll tear into it again. Hope i can buy those bulbs.
thanks.
jim
Old Dec 30, 2007 | 12:40 PM
you can, we get ppl coming in for it all the time. the first time they complained the bulb didn't illuminate when the headlights were on. of course it's such a faint light and i'm like....is it on... i can see....hehe(bright shop)
cbo111
Apr 27, 2013 07:39 AM
chafey
Jan 10, 2009 04:38 AM
yoggi
Feb 1, 2008 07:51 PM
24VCoupe
Sep 22, 2007 11:36 PM
jerij
Aug 13, 2007 09:35 PM
