Accord Bogging?
Old Sep 12, 2011 | 01:38 PM
  #21
jfidelh's Avatar
Originally Posted by MysticBlueEX
Sounds like you are barking up the wrong tree. My other car was doing this and it turned out to be the fuel pump.
also, ">My maintenance requires light flashed 10 times every time i start the car."
is reset the oil change light.
Dang, I was honestly thinking it had something to do with that because when I would slam on the gas for a while it would ride good, so in a way beating it so it wouldnt act up. Even with the new map sensor it would still bog so I got mad and I would slam on the gas, after that, it rode good for the rest of the ride till I got home but after I drove it later that day it started acting up again. I should still have warranty on it!
Old Sep 13, 2011 | 12:50 AM
  #22
jfidelh's Avatar
I do still have warranty! Im going to get the new pump tomorrow and replace it. Ill let you guys know if it solved the problem!
Old Sep 13, 2011 | 10:34 AM
  #23
MysticBlueEX's Avatar
Almost A Senior Member
When my fuel pump was going bad, I would step on the gas out of the toll plaza, and it would vuvvuvvuuuv vuvvuvvuuuv vuvvuvvuuuv about 20 times right in a row. Other times it would run well. especially driving slowly or in traffic, but out of the gate it would bog.
I tried a lot of things, injector cleaner, premium fuel nothing worked.
The other thing it would do when I had 1/3 tank or less it would stall going around the ramps to the highway.
Ford replaced it under warrantee, 3 times as a matter of fact. Junk every time until the third one was finally a good one.
Thats when I decided that it was about time to get another Honda.
Old Sep 13, 2011 | 10:39 AM
  #24
jfidelh's Avatar
How again??
"vuvvuvvuuuv vuvvuvvuuuv vuvvuvvuuuv "
ha jk. Yeah ..Thats what my Accord does. Yesterday after not driving it for about 3 days it drove right for about a mile then acted up again. I missed that steady, no problematic driving -____-
When I get back from class I will begin thenew fuel pump transplant surgery.
Old Sep 13, 2011 | 03:49 PM
  #25
jfidelh's Avatar
Originally Posted by jfidelh
How again??
...awaiting arrival of fuel pump to auto parts store. 1 hour remaining.
Old Sep 13, 2011 | 11:19 PM
  #26
jfidelh's Avatar
FAIL.
Good try tho, Since it was free after all to get a replacement and I changed it myself.
Its actually riding worse now -.-
New map sensor didnt fix it, just improved it. New fuel filter didnt show a difference. uggh
Old Sep 14, 2011 | 12:30 AM
  #27
You might want to check the main relay, since all the other things you tried haven't solved it. See these links:
preludepower.com/forums/showthread.php?t=327176
techauto.awardspace.com/mainrelay.html
Old Sep 14, 2011 | 12:46 AM
  #28
jfidelh's Avatar
Will Do, thanks.
Old Sep 14, 2011 | 12:51 AM
  #29
jfidelh's Avatar
All this started when I
>Fixed 2 exhaust leaks(near cat) & (downpipe). Then it started fluctuating. So I took the intake manifold apart cleaned it all up with carb cleaner. Made it all pretty and what not. Turns out that solved my high idle problem.
All my problems were solved but one arose.
This bloody "BOGGGG" that it does.
It's irritating me. Maybe I didnt put something back on how it I was supposed to?
I removed the fuel rail, maybe I didnt put that in right either?
I also messed with the >throttle plate< stop screw. Could have left it too open or not enough.
I would take it to a mechanic but I dont have the funds to do it.
Damn car feels like im HAULING A BOAT D;
Old Sep 14, 2011 | 12:54 AM
  #30
jfidelh's Avatar
That thread took me to this link.
Testing a Honda Main Relay - Honda Main Relay Test - How To Test a Main Relay
"NOTE: If the car starts and continues to run, the main relay is okay."
My car stays on, doesnt stall.. Just bogs, bogs horrible
