accord coupe 2005, 99000mile
Old Jan 23, 2010 | 11:55 PM
go2maxim's Avatar
Default accord coupe 2005, 99000mile
I just had the oil changed for the car and I didn't know what kind of oil was used before and i just put regular oil in. IT SEEMS THAT THE CAR ACCELERATES HARDER AND WHEN ACCELERATE FROM 0 TO 30 MILES, THE RPM'S ARE HIGH THEN EVERYTHING IT'S NORMAL...I WONDER CAN WRONG ENGINE OIL CAN MAKE MY CAR SLOW AND GIVE IT A LOT OF TROUBLE ACCELERATING FROM STOP OR MAYBE IT'S A PROBLEM WITH THE GEAR BOX ??
Old Jan 30, 2010 | 10:39 AM
Arrow
Watch Your Posting threads..you had this in the Sights and Sounds forum Not quite for that area..I moved you over to here..
Thanks for posting..now you should get an answer...
Old Jan 30, 2010 | 01:56 PM
kris_loehr's Avatar
What weight oil did you use? if you used a heaver weight oil it could crank slower in the cold. At 99,000 the clearance for the rods and mains bearing are mostly likely looser than new anyway. I don’t think you have a problem from the oil change until you went with something really thick like 50W .
pedalfaster
Apr 19, 2007 03:01 AM
Platinumxx80
Feb 22, 2006 01:18 PM
km6f9dm
Nov 14, 2005 10:56 AM
SilverBullet
Sep 27, 2005 01:26 AM
pythonbunny
Jun 10, 2005 07:04 PM
