Actuator Driver side door removal 93 accord
Hi.
All my power locks work Except for the DS door, I hear the clicking, but the lock doesn't engage, meanwhile all the other door locks work fine both from inside controls and the key. Since all others work and I still hear the click, I am assuming I'm dealing with a bad or possibly in need of repair actuator and not the actual door lock control box (can someone confirm this assessment?) OK so I've found instructions to remove the actuator for different models here, on youtube and in general just online..armed with that info I removed the panel and found out the instructions to remove the actuator for my 93 accord 10th anniversary (LX) HAVE to be different than the other generations accords. to give you an idea...I couldn't even see the screws I see so clearly on the pics I've seen here for other models...So this is why I'm here folks. Any help would be appreciated. I intent on fixing the actuator...ive found some pretty good threads on how to do that..i just need to get the thing out! Thanks! I hope this is the right place for this thread. |
2 Attachment(s)
For your car, the power door lock actuator is replaced as a whole with the door latch. Honda discontinued a replacement actuator cover/motor (part #25) years ago.
https://www.hondaaccordforum.com/for...ine=1379692051 |
Would you mind adding a link from maybe ebay or anywhere so I can see the part that needs replacing? I'm not very familiar with the actuator component, and I don't wanna buy more or less of what I need. not sure what you mean by door latch..
