Air Compressor Advise
Old Jul 14, 2007 | 06:28 PM
ricj
Default Air Compressor Advise
See lots of fliers selling air compressors for rachet/socket type work for $200 or so. Power about 1HP to 3HP. How do these compare with the actual air tools used in the auto repair shops. Would these 3HP tools be good enough for personal garage work on own car or need to go upto 10HP etc. to have decent going ons with the repair work.
Old Jul 14, 2007 | 10:51 PM
deserthonda's Avatar
Default RE: Air Compressor Advise
I honestly could not tell you .. I have never used a small air compressor so i do not know what power they cay give out .. Hopefully some other member will know the correct reply
Old Jul 15, 2007 | 04:22 PM
Baker's Avatar
My thoughts:
Home/shop needs about 5 CFM supply at 100 PSI. Tire dealers use 10 HP, usually two. You will need hoses and a regulator. Be careful to select a unit that does not exceed about 10 amperes full load current or you will trip electrical panel circuit breakers. The 5 CFM needs to exceed the usuage of your tool.
Old Jul 15, 2007 | 09:07 PM
smaglik's Avatar
interesting...i will probably be going this route when i finally have a garage to put the stuff in.
ak474u
May 4, 2015 11:15 PM
duffysco
DIY Answers.
May 18, 2013 06:43 PM
dawgs2269
Jul 26, 2011 12:01 PM
JDennis928
Jul 5, 2011 08:02 PM
Johnene
Aug 15, 2009 01:13 PM
