Air Conditioning Sour Odor
Old Apr 19, 2009 | 01:35 AM
dragonle87's Avatar
Default Air Conditioning Sour Odor
Does anybody have any suggestions?
You can only detect the smell when you set the AC on minimum, not full blast....
Thanks
Old Apr 19, 2009 | 01:42 AM
finch13's Avatar
Most likely mold in the A/C evaporator tray in the dash because of a clogged drain line. It would be tricky to clean out, most just spray disinfectant through the air intake near the windshield wipers to kill off mold and bacteria. It doesn't completely solve the problem though.
Old Apr 19, 2009 | 08:46 AM
falkore24's Avatar
shoot chlorox clean-up into the interior filter opening in the glove box.
Old Apr 19, 2009 | 01:26 PM
dragonle87's Avatar
Air intake near the windshield wipers???
Is that where there are 2 tabs (1 on the driver & 1 on the passenger) in front of the windshield?
do you mean the air filter cabin?
Old Apr 19, 2009 | 02:04 PM
cjdm98's Avatar
Directly under your wiper are two vents,ridged with lines. Spray the disinfectant through there as well as through the cabin air filter..located behind the glove box.
Old Apr 19, 2009 | 02:21 PM
finch13's Avatar
No, it's where the A/C cabin filters are located, you have to take the glove box out (6 screws) after removing the lower dash panel (3 screws). It's kind of tricky to do.
I think that's where it is, but I'm not sure. I'd think water would get sucked into the air system.
Old Apr 19, 2009 | 02:55 PM
cjdm98's Avatar
Very good point, but i also believe there is a valve to prevent that,similar when to when you have your A/C to central air,rather than outside air..In retrospect that's where the outside air travels through.If im not mistaken.
Old Apr 20, 2009 | 12:04 AM
dragonle87's Avatar
I see....man I just replace me air filter cabin...now I gotta take it out again
It doesn't matter any kind of disinfectant? Such as for cuts & bruises or what not?
& do I need to turn on the A/C when spraying the disinfectant?
Thanks
Old Apr 20, 2009 | 12:18 AM
cjdm98's Avatar
Lysol, or Clorox or even generic disinfectant will be fine..And yes in order for everything to circulate,a/c should be on max..and set to outside air,rather central.
Old Apr 20, 2009 | 03:22 AM
Although the cabin air filter should prevent this from happening, the drain tube for the evaporator could be clogged.
Condensation from the condenser would sit in the evaporator and turn into moldy water as it sits causing the smell problems.
You should check the drain hose for the a/c evaporator is free of debris. Use a pipe cleaner or a straightened metal hanger to remove anything blocking that tube.
