Another concered question
Hey sorry got another question :p
99 Honda Accord EX V6 (automatic trans) 161,000 miles Beside the transmission problems I have been doing allot of heavy idling for hours a day as I am a traveler and don't like to spend big bucks on hotels.. now I know idling isn't good for the engine but I have to do it at this point.. Now I had the check engine light come on at one point and I took it in for a code check and it came up with something like (can't fully remember) catalytic efficiency code p0420 (I think) and lately I have been having problems with it starting or idling rough.. sometimes I will start it and it will die out right away, like it aint getting enough gas or something then I will have to lay down on the accelerator over about 2000 rpm for a couple seconds and it will then idle out fine, but most of the time it starts up and stays on and I can drive away like normal.. the check engine light is now off and no code is coming up but it is still acting funny :confused: any suggestions, i hope it aint the catalytic converter but if it is .. i guess that would explain.. still not sure, :confused: thanks guys! :o |
Does the D4 light start flashing? I would still stop by a parts store and have the codes scanned just to be thorough.
Are you maintenance items up to date, like distributor cap, distributor rotor, and the spark plugs? Don't forget that letting the engine run while parked adds miles to the plugs, cap, and rotor, but does not add miles to the odometer. The same thing goes for the timing belt. When the car is running normally, can you get the car to stall out by shaking the key? |
Originally Posted by PAhonda
(Post 233647)
Are you maintenance items up to date, like distributor cap, distributor rotor, and the spark plugs? Don't forget that letting the engine run while parked adds miles to the plugs, cap, and rotor, but does not add miles to the odometer. The same thing goes for the timing belt. When the car is running normally, can you get the car to stall out by shaking the key? I had replaced the ECU unit during the summer as I was having stalling problems and that fixed it so.. no when I shake the key everything is ok... so far just a random stall problem when I first start it up after idling along time but it runs when I give it gas for a couple seconds :confused: |
The cap and rotor probably run about $40 from the dealer for the parts.
| All times are GMT -5. The time now is 08:20 AM. |
