Apexi Neo Help anyone???
Old Nov 15, 2008 | 06:53 PM
CubanAssasin187
Default Apexi Neo Help anyone???
I need help learning how to use the vTEC uNMATCH function. I'm getting over 330 whp but it distorts horribly going into and out of vtec.
Anyone know how to work the "UN-MATCH".?
Old Nov 17, 2008 | 09:11 AM
falkore24's Avatar
Default RE: Apexi Neo Help anyone???
It has to do with the transition into or out of VTEC. Look at your VTEC hi and low maps to see how the correction veries between the 2 at the engagement and disengagement points. Set the unmatch to the difference between the maps as a starting point. If there is still a harsh engagement, back the unmatch off a point at a time toward 0.
It sounds to me like you are turbo and your issue is more caused by the VTEC engagement in relation to the turbo going into boost. If this is the case, I'd suggest going to a slightly lower pressure wastegate spring and getting back to the boost pressure that you want with a boost controller. This will make the wastegate operation more accurate and quicker. Make sure that VTEC is engaged before the turbo hits boost.
daemon44
Feb 2, 2009 12:13 PM
BuntinBoy9
Apr 23, 2007 12:42 AM
slicendice
Mar 21, 2007 08:56 PM
ncsgoofy
Jan 8, 2007 03:49 PM
ftgibson
May 21, 2006 12:42 PM
