Appropriate fuel?
Old Aug 15, 2007 | 10:59 PM
HONDZ
Default Appropriate fuel?
Hi,
My manual sttes I shuld use premium n my '03 EX V6.Not being car savy,hat's the big deal if I use regular?I definitely want t do the smart thing.Just bought it.
Old Aug 15, 2007 | 11:36 PM
Baker's Avatar
Default RE: Appropriate fuel?
Why not look in the owners manual??
Old Aug 16, 2007 | 08:46 AM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: HONDZ
^ He did.
If the manual says use premium, you need to use premium. Are you sure it says to use premium though? I didn't think any stock Honda's used premium gas. I thought premium was for Acuras.
Old Aug 16, 2007 | 09:17 AM
RTexasF's Avatar
Super Member
The '03 V-6 specifies 87 octane. I think you need to re-read that manual. Is there a sticker at the gas fill stating premium fuel only? I think not if it is a US car.
SPECIFICATIONS
2003 Honda Accord Coupe EX V6
Base Price $ 25,900
Price As Tested $ 26,360
Engine Type single overhead cam 24-valve V6 with
VTEC variable valve lift and timing
Engine Size 3.0 liters / 183 cu. in.
Horsepower 240 @ 6250 rpm
Torque (lb-ft) 212 @ 5000 rpm
Transmission 5-speed automatic
Wheelbase / Length 105.1 in. / 187.6 in.
Curb Weight 3294 lbs.
Pounds Per Horsepower 13.7
Fuel Capacity 17.1 gal.
Fuel Requirement 87 octane unleaded regular gasoline*******************************
Tires P205/60 VR16 Bridgestone
Old Aug 16, 2007 | 09:21 AM
Registered User
^ that is exactly what I thought. Re-read the manual. Or, post an exact quote from the manual here in this thread regarding what type of fuel it tells you to use.
Old Aug 16, 2007 | 12:39 PM
HONDZ
Oops! Appologies.It states use Preuim grade engine OIL!! I misread it and thought it was the fuel wich is in fact 87 octane.Thanks!
Old Aug 16, 2007 | 02:43 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Aug 16, 2007 | 03:25 PM
Velocifero's Avatar
ORIGINAL: 00AccordLX5spd
ORIGINAL: HONDZ
^ He did.
mine calls for premium [sm=smiley19.gif]
Old Aug 16, 2007 | 04:14 PM
deserthonda's Avatar
you cau use 87 octane ,no problem ,,, or higher if so you choose
Old Aug 16, 2007 | 04:34 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
