axle help
ok so someof u no im doin an auto. to manul conversion on my car...im putn a h23 tranny in now i no its bolts up and evrythng but on the driver side the axle didnt fit so i was wondering if a intermmediate half shaft n the axle off a 92 accord would work lenght wise bcuz a half shaft off a prelude cost to much to buy new and there hard to come around in the junkyards....so does any1 no anythng that would help..thnx..
Will one of your auto axles slide into the htrans? If it does, i would just bring the auto halfshaft with you when you get the manual int shaft and eyeball the ends to make sure they are the same. I would think the accord int shaft should fit without any probs though. And please change the "v4" in your sig to I4, since you have an inline 4 cyl.
yea they could slide in the htrans with no problem..it jus the driver side is a bit short...so i found out the they used n int. half shaft and n axle on the driver side n it stats that its use for accord with h22/23 engines so i was wondering if itll work...
