axle help
Old Feb 5, 2009 | 06:17 PM
littledrakon's Avatar
Default axle help
ok so someof u no im doin an auto. to manul conversion on my car...im putn a h23 tranny in now i no its bolts up and evrythng but on the driver side the axle didnt fit so i was wondering if a intermmediate half shaft n the axle off a 92 accord would work lenght wise bcuz a half shaft off a prelude cost to much to buy new and there hard to come around in the junkyards....so does any1 no anythng that would help..thnx..
Old Feb 6, 2009 | 10:26 AM
jcocker03's Avatar
Will one of your auto axles slide into the htrans? If it does, i would just bring the auto halfshaft with you when you get the manual int shaft and eyeball the ends to make sure they are the same. I would think the accord int shaft should fit without any probs though. And please change the "v4" in your sig to I4, since you have an inline 4 cyl.
Old Feb 6, 2009 | 12:15 PM
yea they could slide in the htrans with no problem..it jus the driver side is a bit short...so i found out the they used n int. half shaft and n axle on the driver side n it stats that its use for accord with h22/23 engines so i was wondering if itll work...
Old Feb 6, 2009 | 12:39 PM
I have a h23 half shaft you can have for $40+ shipping. And also have some axles if need be.
I dont think 90-93 accord axles will work.
Old Feb 6, 2009 | 03:42 PM
ill b glad to take that off ur hands....n do u have the drive side axle to go along wit the half shaft? and can u give me the total of evrythng..
Old Feb 6, 2009 | 03:54 PM
I have an accord halfshaft an axle and just a h23 half shaft, I can do $60 plus shipping for any combination of halfshaft and axle. where are you located? I'll get a shipping quote.
Old Feb 6, 2009 | 04:05 PM
im am located in phoenix az 85017..and will the accord axle fit the h23 half? if not then ill jus take the h23 half shaft..
Old Feb 6, 2009 | 04:08 PM
You will need a prelude/accord axle and halfshaft. I would think they would work with each other, but I cant be sure. I personally have never done a auto to manual conversion.
Old Feb 6, 2009 | 04:10 PM
ok ill jus take the h23 half shaft
Old Feb 6, 2009 | 04:13 PM
That will be $60 shipped including paypal fees.
