Bad cranking sound, Doesn't start car(Video)
Old Nov 23, 2011 | 02:02 AM
mhassanz's Avatar
Angry Bad cranking sound, Doesn't start car(Video)
Hi everyone,
I found that forum online while searching my car's issue. I know you cant tell anything without look at the car, but still I upload a video to look at and give me some idea what could be the problem. Here is the story. Its 2010 accord 25000 miles on it. I installed a after market remote start professionaly the expensive one Viper 5902. Everything was fine, But recently my car starts giving me a problem. When i start my car it cranks soooo bad , scare the hell out of you, sometime people look at you . It does start on second attempt mostly. it does happen alot but not all the times, but i notice it strats getting worse and worse. I know I should stop to a dealership, but i need you opinions like what could cause that problem? it does the same thing with key start so its not a remote-starter problem. Here is the video check it out. Accord cranking problem - YouTube thanks.
Old Nov 23, 2011 | 06:52 AM
Sounds like a bad starter, however suggest having battery tested and battery wires checked carefully, cleaned, and secured. Low voltage can cause this symptom also.
Old Nov 23, 2011 | 08:10 AM
To add to what TX already suggested/asked.
Does it do the same when you use the key or only when using the remote start?
Old Nov 23, 2011 | 12:15 PM
mhassanz's Avatar
Default same with key
it does same thing with key as i said in my first post. Battery is good wiring is like new
giulio76
Dec 29, 2012 11:16 AM
Peacemaker98LX
Jan 15, 2011 09:05 AM
fishin4fun
Jul 20, 2009 07:52 AM
faosh
Mar 28, 2009 02:59 AM
patpatho
Dec 27, 2006 04:50 PM
