Bad distributor?
Old Aug 15, 2008 | 09:16 AM
nodough
Default RE: Bad distributor?
So my car has an internal coil since there are only four wires on the distributor cap? I'm not quite sure I understand what you mean by jumping the service connector. I clicked on the link in your post but it said "file not found".
Old Aug 15, 2008 | 10:03 AM
1992 is the first year with the SCS connector. On your 91, you pull back the passengers carpeting & look for a blinking LED.
http://www.troublecodes.net/honda/
Old Aug 15, 2008 | 10:32 AM
nodough
So do I try to jump the blinking led? And the codes I'm looking for come up on the dash as a series of blinking lights right? Or will it be a number?
Old Aug 15, 2008 | 10:43 AM
Old Aug 15, 2008 | 10:55 AM
nodough
The link works now. Thanks for all the help. I'll post the codes later.
Old Aug 15, 2008 | 11:24 AM
ORIGINAL: nodough
So do I try to jump the blinking led?...
LOL
OK, the first thing that crossed my mind wasnt very nice... so Ill keep it to myself.
I never had a Hondafrom those years, but I think you dont do anything except count the blinks.
I hope the links help.
Old Aug 15, 2008 | 11:54 AM
  #17
The SCC was available in 1990 and probably 91 as well. I had a 90 and it was under the glove box.
Coil is more likely than ignitor in my experience, but there is a DIY diagnostic to distinguish between the two faults. Coil secondary resistance measurements can be misleading and primary is very close to zero resistance.
Old Aug 15, 2008 | 12:10 PM
  #18
falkore24's Avatar
Also, if those new spark plugs say Bosch on them, then it is likely that they killed the coil.
Old Aug 15, 2008 | 04:32 PM
  #19
So Tex... In 90 & 91, the SCS connector was there? The link about troublecodes says up including 91 you have flashing LED on the ECU itself.
Im curious so I dont keep giving people bogus information...
Old Aug 15, 2008 | 05:09 PM
  #20
I think that the SCS connector is there on all the 4th gen accords.
I think that you can always count the LED on the ECU for all 4th gen accords. The CEL light must only flash the code on 92+ accords?
