Bad Power Steering Pump
Old Sep 26, 2006 | 06:04 PM
WhyNotFab's Avatar
Default Bad Power Steering Pump
My power steering has been working whenever it feels like it.. belt is good, I have fluid.. but I'm pretty sure it's the bearing inside the pump. (Couple of friends with Hondas have agreed)
So I was wondering, is this bad bearing taking power from my engine? If so.. would it hurt to just cut the belt off until I replace the pump (asap)? Just so the fluid will stop bubbling/overflowing/steaming.
I can deal with no power steering, my old truck had none.. so maybe it'd be ok. Let me know!
Also, could I trust PS Pumps off ebay, etc? How much should I expect to spend and how hard is the replacement?
Old Sep 26, 2006 | 06:18 PM
sir_nasty's Avatar
Default RE: Bad Power Steering Pump
$232.00 remanufactured...
http://www.hondapartswarehouse.com/p...%20%2019%20%20
Old Sep 30, 2006 | 05:15 AM
WhyNotFab's Avatar
After my car warms up, the PS reservoir looks as if it's smoking/steaming but it doesn't feel hot anywhere on the hoses.. and it bubbles, sometimes overflowing. The pump itself makes a noise.. a few friends told me a bearing is going out, so randomly my PS will work and not work. Would a new pump fix this, or is it something different if it's bubbling like that? What's causing that bubbling?
Old Sep 30, 2006 | 05:25 AM
deserthonda's Avatar
if the pump is not working properly,, instead of pumping fluid through the system , it could cause some air pockets to be built,, thus the reservoir will oveflow ,,,
it is as if you keep on turning the wheels with the engine off,, fluid in the p's reservoir after a bit will spill over
giulio76
Dec 29, 2012 11:16 AM
Rizzie
Aug 21, 2006 03:26 AM
BDN54
Mar 9, 2006 02:34 PM
WS6M21
Dec 4, 2005 11:37 PM
WS6M21
Nov 9, 2005 01:50 AM
