Bad radiator fan motor
Old Aug 22, 2010 | 01:24 PM
bjr001's Avatar
Default Bad radiator fan motor
Hello,
I was having some problems with my AC not always cooling properly. Sometimes the air would be cold other times it would take driving for a while for the ac to began to cool again. If I drove the car a little hard then ran into stop-n-go traffic I noticed the temp go high but not over heat.
Yesterday after experiencing this again I opened the hood and saw that the radiator fan (driver side) was not running at all while the other fan was running while the AC was going. I turned off the AC the passenger side fan went off. I then tapped the electric motor of the driver side and the fan began spinning. It appears the motor has been failing.
Are there any places that rebuild Honda fan motors or just buy a new motor online?
Thanks
Old Aug 22, 2010 | 01:30 PM
Never seen a place that rebuilds them. Just look online for a replacement if you are sure it is bad. On a 4 cyl the left drivers side is usually called the condensor fan.
Old Aug 22, 2010 | 07:51 PM
tyjoja's Avatar
Default 88
on my 88 the drivers side is the a/c also
Old Aug 23, 2010 | 01:34 PM
deserthonda's Avatar
he has a v6 engine driver's side IS the cooling fan motor .........a/c condens fan is on pass side ..........on a 4 cyl engine they are the opposite
Bj just buy an after market fan motor ,,a lot cheaper than factory part
Novaknowledgenow
May 30, 2013 08:58 PM
hondap
Mar 19, 2013 06:27 PM
everyinchofgod
Jul 30, 2010 03:55 PM
daddy
Feb 6, 2006 02:52 AM
