battery ?
Old Feb 12, 2008 | 01:18 AM
status's Avatar
Default battery ?
i.ve notice that since ive had my accord if lights are on if i push a radio button or signal or push curise lights dim. i know thats usually normal but in my last 2 cars its never been that week. could it use a new batt. ? i assume its the orignal batt. should be 2 1/2 years old.
Old Feb 12, 2008 | 07:18 AM
Default RE: battery ?
Does it do this when the engine is running? If so, then check for loose/dirty/corroded connections at the alternator & the engine-to-body ground wire.
In any case, check the battery cables (both ends) too.
Firstrule out wiring, but if this is happening when the engine is running, it sounds more like a weak alternator.
togles
May 9, 2017 07:32 AM
matttv
Aug 12, 2013 03:50 PM
cadams8221218
Jul 15, 2011 07:24 AM
RoKnAzn
Jan 19, 2007 01:56 PM
zelseman
Dec 11, 2005 11:44 AM
