Battery for 2013 Honda Accord 6-cylinder
My dealership tested my battery and says it needs replacing. They quoted $208. I thought that was high. I hadn't checked battery prices in years and I see they're twice as expensive as they were when I last checked ~ 2012.
I'm thinking of replacing the battery myself.
My owners manual says for my battery: Capacity/Type: 60AH (5) / 72AH(20). I'm not sure how to translate this information. I believe AH stands for Amp-hours but really don't understand Capacity vs Type and the numbers in parentheses. Assuming I find a compatible battery, is there any thing I need to worry about? Also, does anyone know what systems will need reconfiguring after the battery power shutoff-restoration?
Or should I just let the dealership take my money?
Also they said that my cabin filters were dirty and need replacing. ($116) That was surprising to me since I haven't been driving in dirty conditions. Anyway, is replacing cabin filters something the owner can accomplish easily? I also have no idea where they are
I appreciate any help here. TIA,
Paul
Paul
I don't believe that any systems will require reconfiguring when you change a battery. Verify in your owner's manual, but you should be able to do this yourself.
All aftermarket batteries will match the proper battery specific for your accord. The v6 accord is a common vehicle, so you should have no issues finding the proper battery. Most parts stores will change the battery at the store as a free service.
Your owner's manual should have instructions on how to replace the cabin air filter. It is pretty simple to change.
Here is a good youtube video.
Amp-hours is correct, but I don't recognize the notation in parentheses. Maybe 60 amp-hours at 5 degrees?
If you go to a car-parts store, they will just want to know your car's year, make, model, etc.
The cabin-air filter is easy.
In case its really dirty, have a vacuum cleaner for any crud spilling out when you pull out the filter.
LOL, I had this thread open awhile before writing the response. PA beat me to it...
Those prices are outrageous. You can get a Die Hard AGM battery (10% off code DH10) from Advance Auto and a K&N filter (reusable filter) and still have over $90 left for an oil change, tank of gas, car wash and snacks from the gas station. 😂
That was my impression. I used to change my oil myself. This time I couldn't even loosen the oil pan bolt for some reason. I decided to take it to the dealership finally. $186 for an oil change and tire rotation. Seems too much. I'm getting too old (70), though, so I may have to support other folks lifestyles
Could jusst go to nearest Walmart Auto Center and inspect the batteries on a rack, like I did this last time. There were two options that fit my Accord; I got the slightly larger capacity one and they installed free, rather quickly, for $109 (two yrs ago).
