Battery terminal bolt won't tighten
Old Jun 23, 2024 | 02:03 PM
albertkao9's Avatar
Default Battery terminal bolt won't tighten
My car battery negative terminal bolt is so loose that it come off.
I failed to tighten it with a 10MM socket wrench.
Please note that I can tighten my car battery positive terminal bolt.
Please see the attached photos.
How to tighten the 10MM car battery negative terminal bolt?
Old Jun 23, 2024 | 02:56 PM
A battery post shim may fix it, which are sold at auto parts stores.
Some people just stick something that is conductive metal in between the terminal; but, a shim made for the post is better.
Old Jun 23, 2024 | 04:14 PM
albertkao9's Avatar
Old Jun 23, 2024 | 06:27 PM
Yes, that should work. Those are the battery post shims I was referring to.
Old Jun 24, 2024 | 06:18 AM
albertkao9's Avatar
Thanks!
PatG
Jul 13, 2023 04:46 PM
SJ443
Nov 16, 2022 10:43 PM
seattleslew
Jun 5, 2013 11:53 PM
daftshadow
Jun 21, 2011 06:30 PM
hondarelic
Jan 19, 2010 06:44 PM
