best spark plugs?
Old May 7, 2024 | 08:19 AM
btartus's Avatar
Default best spark plugs?
looking to replace spark plugs in 1995 Honda Accord LX 2.7L. whats the best options? NGK? Iridium? Non Iridium? dont need to break the bank but want high quality plugs. i have NGK wires.
Old May 7, 2024 | 12:38 PM
Use the NGK plugs that are specificed for your car. There should be a sticker under the hood that tells you the NGK part number. I believe the 95-97 V6 accords used copper electrodes, so the NGK ZFR5F-11 (please verify on your sticker under the hood or the owner's manual). These plugs get changed every 30K miles as they wear faster than platinum/irridium.
As long as changing the plugs is not a pain on the V6, I'd stick with the OEM plugs that are cheaper and have more frequent changes.
Old May 7, 2024 | 02:05 PM
btartus's Avatar
great! thank you!
Old May 7, 2024 | 04:16 PM
btartus's Avatar
I was thinking about this. arent I better off using a platinum or a double platinum plug that lasts much longer if I am paying the labor to do it.
Old May 7, 2024 | 05:00 PM
If you are paying a shop to do the work, then use NGK PZFR5F-11. These are the platinum plugs starting with the 2000 accord and replaced the copper (or nickel) ZFR5F-11.
They can be changed every 105K miles.
Old May 7, 2024 | 05:07 PM
btartus's Avatar
sounds like the right plan! thank you!
Old May 7, 2024 | 05:14 PM
btartus's Avatar
so starting with 2000 accord they will work perfect on my 1995 2.7L? they are $35 on Rock Auto and $58 on Amazon and $70 on the NGK website. Cant beat Rock Auto pricing.
Old May 7, 2024 | 08:40 PM
So the 98-99 use the ZFR5F-11 (same as your 95 engine), and the 00-02 accord use the PZFR5F-11. These are the same engines, so the PZFR5F-11 just has a longer lifetime to change them. You should have no issues.
Old May 7, 2024 | 09:35 PM
btartus's Avatar
great! again thanks for your help!
indy49
Aug 5, 2016 10:46 PM
Ninja
Mar 3, 2012 06:16 AM
Antarctica
Jun 22, 2010 11:24 AM
Adam182R
Jul 4, 2007 12:09 PM
maro
Dec 31, 2006 04:59 AM
