Blower motor relay location
:eek:I am trying to find the location of the blower motor relay on a 1988 Honda Accord LXi. I was able to test the blower motor located under the right side dash and it checked OK. I would appreciate any suggestion or help.
RE: Blower motor relay location
what is the problem that you are having ?? there is no relay
[:@]The blower motor does not come on when I select any of the four settings on the switch. I ran a direct 12 volts to the blower motor and it runs just fine. According to a manual it states there is a relay in the circuit. Perhaps the manual has a misprint. The only other thing possible is the switch inself. However, I have never seen aswitch fail on all four positions. Thanks for your reply. Do you have any other suggestions?
ORIGINAL: billgrego Do you have any other suggestions? If you applied direct power to blue/white and motor worked , i would have to assume that the ground path ( blue/black ) is ok,, SO .. sounds like you are not getting any power at blue/white wire power on that wire comes from the ignition switch ,, you need to chk that there is power at blue/white wire coming out of ignition switch,, If there is NOT and fuse was ok,, most likely you got a bad ignition switch ,, ( chk as close to switch as possible ) to avoid the possability of a broken wire ..........Now if you got power coming out of the switch and no power at blue/white at blower motor you got an open in the blue/white wire somewhere |
Thank you for your time. I will make the tests you suggested. I did check the 40 amp fuse and found it OK. I will get back to you if and when I find a solution to the problem. Again thanks for the time you have given to my problem.
billgrego |
:D
deserthonda, the ignition switch is bad. At the blue and white wire coming out of the switch, I fed 12 volts directly into it. The blower motor came on. All speeds worked also. It was only a matter of time before the ignition part of the switch failed, probably leaving me stranded somewhere. I felt the back of the switch and it was a little hotter than normal. Thank you for your help. You had the problem figured out correctly. I have a Dodge Dynasty which was continually burning out the blower motor part of the ignition switch. Sometimes after aging, a blower motor will pull more current. This can result in early ignition switch blower motor failure. After replacing three ignition switches, I put a relay in the circuit. Now the ignition switch only had to supply a little current to close the relay. The relay fed 12 volts through an inline fuse directly from the battery to the blower motor. It's been 4 years and no more ignition switch burnout. I am going to replace the Honda ignition switch and put a relay in the circuit. Again thanks for your help. |
glad to hear that you got it resolved........you should only replace the electrical part of the ignition switch , it costs around 60-80 dollars at the dealer
| All times are GMT -5. The time now is 02:35 AM. |
