Bought 89 ACCORD LXI HELP!!!
OK. I bought this car for $350, and was told it just needs a head gasket! Apparently a water pump was installed wrong, and water got in with the oil. What is the worst case scenario here? Doe's anyone have any suggestions? appreciate any help.
regards |
RE: Bought 89 ACCORD LXI HELP!!!
no thats not from installing the water pump wrong....thats from it having a bad head gasket. water gets in the oil and oil gets in the water. the seal in the head went out. and that seal keeps oil, massive explosions, and coolant separate from eachother. its a bad scenario to start with..... have you ever changed a head gasket? if you have.......then you have nothing to worry about. sometimes if the car is allowed to overheat real bad the head will warp. cause alluminum doesnt really like to get hot, but i wouldnt worry about that. feel free to pm me.
ORIGINAL: fleabag711 OK. I bought this car for $350, and was told it just needs a head gasket! Apparently a water pump was installed wrong, and water got in with the oil. What is the worst case scenario here? Doe's anyone have any suggestions? appreciate any help. regards worse case scenario.. replace the engine ... best case scenario, replace head gasket. mill the head, replace thermostat. and hopefully for you all the fans work properly . |
