Bought 89 ACCORD LXI HELP!!!
Old Apr 7, 2006 | 01:05 AM
fleabag711
Default Bought 89 ACCORD LXI HELP!!!
OK. I bought this car for $350, and was told it just needs a head gasket! Apparently a water pump was installed wrong, and water got in with the oil. What is the worst case scenario here? Doe's anyone have any suggestions? appreciate any help.
regards
Old Apr 7, 2006 | 06:00 AM
lightshow's Avatar
Default RE: Bought 89 ACCORD LXI HELP!!!
no thats not from installing the water pump wrong....thats from it having a bad head gasket. water gets in the oil and oil gets in the water. the seal in the head went out. and that seal keeps oil, massive explosions, and coolant separate from eachother. its a bad scenario to start with..... have you ever changed a head gasket? if you have.......then you have nothing to worry about. sometimes if the car is allowed to overheat real bad the head will warp. cause alluminum doesnt really like to get hot, but i wouldnt worry about that. feel free to pm me.
Old Apr 9, 2006 | 06:07 AM
deserthonda's Avatar
ORIGINAL: fleabag711
regards
someone lied to you,,, you cannpt install a water pump wrong.. this car overheated to the point that it blew the head gasket.. possibly warped head. and collapsed piston rings..
worse case scenario.. replace the engine ... best case scenario, replace head gasket. mill the head, replace thermostat. and hopefully for you all the fans work properly .
mkirby626
Jun 15, 2015 07:48 AM
jdog89
Mar 24, 2010 10:03 PM
mamtsberg
Mar 17, 2010 09:15 PM
viking805fan
Jun 3, 2009 08:16 PM
phil
Apr 5, 2009 07:15 AM
