1989 Honda Accord LXi P/S Pressure Hose Help!!! Please!!!
Old May 29, 2009 | 09:51 PM
viking805fan
Default 1989 Honda Accord LXi P/S Pressure Hose Help!!! Please!!!
So i bought a new P/S pressure hose because it was leaking power steering fluid through the hose and when i check the under the hood the stock one inside the car had some type of sensor socket or chip type of thing connected to the pressure hose. So i have no idea what it is for...the one i bought does not have it attached to it. Here a pic of the one that i bought online...
Old May 30, 2009 | 01:25 PM
viking805fan
Bump...
Old May 31, 2009 | 03:36 PM
hondadude's Avatar
ummmmm well, trying to have a flashback.
I think it was a pressure sensor to signal the computer if the steering was under high load, as in turned all the way to lock.
You should be able to get away not using it, but might have engine stumble if you turn the steering all the way to one side or the other.
Be sure to rewrap the insulation around the hose where it passes over the exhaust manifold when you do the replacement. The heat will cook the hose with out protection.
Old May 31, 2009 | 06:26 PM
Smile Hello Member...
Originally Posted by viking805fan
Bump...
No need to use BUMPS in this forums...please dont.
Welcome to the forums tho..Thanks for joining...
Old Jun 1, 2009 | 12:29 AM
viking805fan
ok thanks for the info. i found a new one with the sensor on it hopefully it works. ill come back 2 let u guys know what happened. thanks again
Old Jun 1, 2009 | 05:06 PM
deserthonda's Avatar
the first hose you got is for the DX LX models. the LXI is the only one that has the opening for the sensor , you have to remove the old sensor and reinstall it on the new hose ,, I am yet to find a hose that comes with the sensor installed ..
pay close attention how to route that hose ,, it could be fun .
Old Jun 3, 2009 | 08:16 PM
viking805fan
Thanks for the info deserthonda...i just ordered another one and looks from the picture that its the correct one for the lxi, i should be getting it by tomorrow so we'll see what happens
mkirby626
Jun 15, 2015 07:48 AM
ncgchlct
Feb 28, 2013 02:26 AM
lindsey453
Dec 29, 2012 10:39 AM
darrenf6
Jul 29, 2012 02:56 PM
jaramillo_guillermo
Feb 16, 2012 07:17 AM
