89 honda accord lxi need help
Old Mar 20, 2010 | 07:16 PM
jdog89's Avatar
Default 89 honda accord lxi need help
i have a 89 Honda accord lxi with a 2.0 sohc and its cut outs about 2800 rpm than when it get to 3800 rpm it takes off and run fines. i want to know if anybody knows about these 89 honda accords?
Old Mar 20, 2010 | 07:28 PM
jasonfridlund's Avatar
pm jimblake or g22, they'll help ya out
Old Mar 20, 2010 | 09:55 PM
jdog89's Avatar
ok thxs
Old Mar 21, 2010 | 09:12 AM
Love to help but I'm not the best expert on Accords back that far.
(yes I AM that old, but I didn't have Accords back then).
Besides I much prefer answering in the forum so it helps other people too.
I just saw a thread where someone's engine stalled just as it reached a similar RPM. Turned out there was red dust inside the distributor. Cleaned it up & it ran OK. But... that red dust means his distributor bearing was shot.
Old Mar 21, 2010 | 10:33 AM
chip's Avatar
Is it carburatorated or fuel injected? How hard are you accelerating?
I need you to describe it better.
Old Mar 21, 2010 | 11:19 PM
jdog89's Avatar
it is fuel injected and it does it all the time and it dont matter how hard u get on it or u are just taking it slow
Old Mar 22, 2010 | 10:04 AM
chip's Avatar
interesting!!
Have you pulled the codes yet? Do you have a book (shop manual) for the car? If not, you need to first go to the parts store and buy yourself a manual, then pull the trouble codes.
Let me know.
Old Mar 23, 2010 | 11:02 AM
jdog89's Avatar
they is no codes at all if u are going by the led on the computer
Old Mar 23, 2010 | 06:49 PM
chip's Avatar
Try tuning it up. Plugs, wires, fuel filter, egr valve, etc.
Always start with the cheapest things first. A good, full tune up might solve your problem (keywords being FULL tune up) and even if that doesn't fix it, you won't be out any money, since the car most likely needs it anyway, plus I'm pretty sure that should fix your issue. You either have a clogged fuel filter, or clogged injectors or something stupid.
Do a top to bottom tune up and let me know if that does it for you.
Old Mar 23, 2010 | 09:34 PM
jdog89's Avatar
i have done that and change the injectors and it havnt change anything. it till does it
