brake light on
Old Jan 1, 2008 | 03:14 AM
ku3kid
Default brake light on
i have a 2001 accord ex v6 and when ever i press down the gas pedal to get moving from a stop, the red brake light comes on. This only happens when i press down on the pedal harder than usual, like half way down, or fully pressing down the pedal. i have checked to see that my emergency brake is not engaged and there seems to be no signs of any braking occuring, but yet the brake light still comes on. Any one have an idea of what the problem is?
Old Jan 1, 2008 | 08:17 AM
Default RE: brake light on
This is likely a problem w/ the float reed switch in the brake fluid reservoir. Honda and Acura have problems w/ this in recent years. I've got an Acura that turns the brake light on w/ startup when temp is cold, and goes off after 10 mins of driving.
You can check if the float switch is the problem by disconnecting one of the leads to the reservoir switch. If problem goes away, you know the reed switch is the problem. A new switch is probably only fix.
Old Jan 1, 2008 | 12:47 PM
HondatechAV6's Avatar
no, the switch is absolutely fine. the problem is the filter.
the filter retains pressure inside it since it creates such a good seal. honda has an updated filter with notches cut into the side of it to equalize pressure faster. you can modify your current filter to look like the updated filter to fix it.
or a new replacement filter from honda is about $10 or so.
be sure to top off your brake fluid level if it's low(use Dot 3 fluid)
Old Jan 2, 2008 | 11:06 AM
00AccordLX5spd's Avatar
Registered User
Hey HondaTechAV6....where is the filter? Can it be seen in this pic?
Old Jan 2, 2008 | 11:45 AM
ORIGINAL: HondatechAV6
By filter do you mean the strainer cup insert in the reservoir? How does this affect the float on the cap?
First I've heard of this. Is there a TSB?
thanks
Old Jan 2, 2008 | 06:54 PM
yeah, there is a tsb on it. all filters that sink into the master cylinder are affected. it usually turns off after the pressure equalizes after you drive off and are about 15 minutes into the drive or so.
it's not in your picture.
what happens is the filter isn't allowing the cap to vent properly. this causes the fluid level in the filter to change. and since the float is inside the filter the warning light illuminates.
the part number is:
46666-S04-J02
if the float is binding upon inspection(the styrofoam type thing that is on the cap) replace that:
46662-S84-999 (although i've never had a binding float, it's always just the filter)
Old Jan 2, 2008 | 07:10 PM
Thanks, this makes a lot more sense than Honda buying that many faulty reed switches.
Regards
Old Jan 3, 2008 | 10:19 AM
falkore24's Avatar
LOL .... they just bought that many faulty filters!!!!
Old Jan 3, 2008 | 12:59 PM
drummer1279's Avatar
thats a new one on me too, I never knew that a master cylinder had a filter.
Old Jan 3, 2008 | 01:40 PM
falkore24's Avatar
well .... faulty screens ...... kinda like a pool filter basket only smaller, so I guess calling it a filter is correct ...... just that it's not a cartridge or can.
