brake lights
Old Nov 3, 2018 | 12:33 PM
sparkiee's Avatar
Default brake lights
Have a strange problem with our 2002 Accord. Suddenly when turning on lights (parking or running) the brake lights come on. The brake lamp light also luminates. Checked and replaced all lamps and inspected all sockets. Nothing found. Brake lights work fine without lights turned on but turn them on and brake lights stay lit. Any ideas what to check. Also by turning light switch on it aactivates transmission release.
Old Nov 5, 2018 | 06:37 AM
Did you check the ground connections for those lamp sockets?
The HAF help area is for questions about how the website works, not car questions. I'm moving this over to General Tech where more people will see it.
Old Nov 5, 2018 | 09:04 AM
rockhoundrob's Avatar
Was any work done to the car before this happened?
Old Nov 5, 2018 | 10:53 AM
sparkiee's Avatar
Have not done anything since transmission was replaced last spring.
Old Nov 5, 2018 | 10:55 AM
sparkiee's Avatar
So answer is no.
sparkiee's Avatar
Car has been in storage.
Old Nov 5, 2018 | 11:03 AM
Most of the lights back there are grounded through G-601 which is a bunch of wires connected to a bolt near the left-rear lamp housing. If part of that is loose or corroded, it can cause things like that to happen in circuits that are "supposed to be" unrelated.
Old Nov 5, 2018 | 11:05 AM
PS... if it's been in storage, you might have to look for damage from rodents chewing the insulation from wires?
Old Nov 5, 2018 | 11:09 AM
sparkiee's Avatar
Ok sounds possible I will check the grounds. Thanks
Old Nov 5, 2018 | 03:52 PM
sparkiee's Avatar
Found the problem. A pin in the right rear turn/brake bulb socket broke off inside the back half of the two piece socket and shorted out to the other pins. Don't know how this happened since this part ususally doesn't comes off when changing lamps.
