Is this brake pad problem?
sometimes when I operate the brake, it makes some noise such as two metals are scratching each other. can you guess what this problem is??
RE: Is this brake pad problem?
Sounds like the pads. Try to determine where it is coming from and pull the wheel to find out.
ORIGINAL: hyungwou85 sometimes when I operate the brake, it makes some noise such as two metals are scratching each other. can you guess what this problem is?? would it be a lot better if you could have done a visual inspection of the brakes first since it is what you suspected anyways ? that's what everyone is going to suggest pull the wheels and chk the brakes and rotors. |
You answered your own question there sport, think about what you said and you'll see your own answer...when you take it apart and you see what your gonna see then ask that question again unless you know about brakes...
WheelBrokerAng [sm=americanasmiley.gif] ORIGINAL: hyungwou85 sometimes when I operate the brake, it makes some noise such as two metals are scratching each other. can you guess what this problem is?? |
Good suggestion there DesertHonda as usual you got your subject to thinking ...we hope..
Are you going to be a regular contributor to our New Forum? We are all looking forward to you joining Myself, LightShow and of course MrNasty:D What say you? are you in?? WheelBrokerAng [sm=type.gif] ORIGINAL: deserthonda ORIGINAL: hyungwou85 sometimes when I operate the brake, it makes some noise such as two metals are scratching each other. can you guess what this problem is?? would it be a lot better if you could have done a visual inspection of the brakes first since it is what you suspected anyways ? that's what everyone is going to suggest pull the wheels and chk the brakes and rotors. |
sure ,,count me in,,
it will be a pleasure to join you guys ,,i will help as much a i can,, ORIGINAL: WheelBrokerAng Good suggestion there DesertHonda as usual you got your subject to thinking ...we hope.. Are you going to be a regular contributor to our New Forum? We are all looking forward to you joining Myself, LightShow and of course MrNasty:D What say you? are you in?? WheelBrokerAng [sm=type.gif] ORIGINAL: deserthonda ORIGINAL: hyungwou85 sometimes when I operate the brake, it makes some noise such as two metals are scratching each other. can you guess what this problem is?? would it be a lot better if you could have done a visual inspection of the brakes first since it is what you suspected anyways ? that's what everyone is going to suggest pull the wheels and chk the brakes and rotors. |
