Brakes
Old Mar 21, 2023 | 04:29 AM
chris0824's Avatar
Default Brakes
Need some advice. I have a 1996 Honda Accord LX. R/S front brake caliper was sticking and the rotors looked bad so I changed both sides. (Rotors, caliper, pads) Now, as I’m bleeding the brakes, there is not enough fluid pressure to the L/S caliper to move the piston. (Which is odd because the L/S was working fine and the pads were worn evenly) what I done shouldn’t have changed the fluid pressure. I thought maybe the hose running from the brake line to the caliper on the L/S may had collapsed (it looked old) so I changed it but that made no difference. I am kind of stuck and don’t want to just randomly throw parts at it with out having some idea where to start. Also I changed out the Master Cylinder about a year or so. Any advice would be appreciated. Non ABS
Old Mar 21, 2023 | 11:03 AM
Does fluid come out of the l/s caliper if you open the bleeder?
Old Mar 21, 2023 | 11:15 AM
chris0824's Avatar
Just a few drops. The right side bleeds as it should. That is what I was doing when I recovered this. My wife came down to help me bleed the new calipers and when she would pump the brake and hold the pedal there was almost no pressure on the l/s.
Old Mar 21, 2023 | 05:31 PM
You'll have to work backwards from the caliper to the brake master cylinder to find out where you are losing pressure. Disconnect at the top of the shock tower and see if you get fluid to come out, the move on to the next place you can disconnect.
Old Mar 21, 2023 | 06:40 PM
chris0824's Avatar
I went ahead and try to bleed all four brakes. I am getting very little pressure to the back r/s and the left f/s. Could it be the master cylinder?
Old Mar 21, 2023 | 08:21 PM
With that other information, it could be the master cylinder.
Old Mar 22, 2023 | 04:12 AM
chris0824's Avatar
I ordered one this morning. I will post when it arrives and I install it. Thanks everyone.
Old Mar 28, 2023 | 03:22 PM
ticktock's Avatar
Thank PAhonda, I learn some thing today.
Ted.
Old Mar 29, 2023 | 01:22 PM
chris0824's Avatar
Just an update. Installed the brake master cylinder. That was the problem. Back on the road. Thanks for all the advice everyone!
domestuff
Aug 3, 2022 05:36 PM
phantomgrey92
Dec 22, 2015 10:24 PM
MessAround
Oct 21, 2012 09:36 PM
HelpMe
Jun 5, 2009 08:45 PM
jmcmichael08
May 14, 2007 09:58 PM
