Brakes are breaking my will power
Here is what I have. 1996 accord 4 cylinder. I put in new master cylinder and blend with vacuum pump. All clean new fluid no bubbles. I have a soft spongey pedal. The car sat for close to 2years. Could the soft lines be going bad and expanding when we step on the brakes?
Originally Posted by Sparetimetoys
(Post 365372)
Also make sure the rear brake shoes/drums are properly adjusted.
If you didn't bench-bleed the new master cylinder, you may have to bleed a lot more fluid through before the last few bubbles come out. It needs pumping action at the MC - the bubbles stuck in there don't seem to come out easily without a lot of pumping.
