Brakes are breaking my will power
Old Dec 12, 2015 | 05:32 PM
Sparetimetoys's Avatar
Default Brakes are breaking my will power
Here is what I have. 1996 accord 4 cylinder. I put in new master cylinder and blend with vacuum pump. All clean new fluid no bubbles. I have a soft spongey pedal. The car sat for close to 2years. Could the soft lines be going bad and expanding when we step on the brakes?
Old Dec 12, 2015 | 06:04 PM
shipo's Avatar
Could be; if that's the case, have someone pump the pedal while you watch the brake hose, you should be able to see it expand.
Old Dec 16, 2015 | 10:00 AM
travrach's Avatar
Also make sure the rear brake shoes/drums are properly adjusted.
Old Dec 18, 2015 | 09:53 AM
If you didn't bench-bleed the new master cylinder, you may have to bleed a lot more fluid through before the last few bubbles come out. It needs pumping action at the MC - the bubbles stuck in there don't seem to come out easily without a lot of pumping.
arnel9872
Feb 13, 2011 12:43 PM
arnel9872
Oct 22, 2010 06:45 PM
05hondaman
Jan 3, 2008 07:26 PM
miami honda
Feb 18, 2007 12:09 PM
AznMaNg282
Aug 23, 2006 10:38 AM
