Brakes are breaking my will power
Here is what I have. 1996 accord 4 cylinder. I put in new master cylinder and blend with vacuum pump. All clean new fluid no bubbles. I have a soft spongey pedal. The car sat for close to 2years. Could the soft lines be going bad and expanding when we step on the brakes?
If you didn't bench-bleed the new master cylinder, you may have to bleed a lot more fluid through before the last few bubbles come out. It needs pumping action at the MC - the bubbles stuck in there don't seem to come out easily without a lot of pumping.
arnel9872
Oct 22, 2010 06:45 PM
