Breaking Problems
Old Dec 25, 2006 | 06:14 PM
miami honda's Avatar
Default Breaking Problems
Hi everyone, well recently I bought 94 accord ex and whne I break the pedal keeps going all the way to the floor with me even putting light preassure on it. Does anyone got any idea what it might be or how much would it be to fix? Oh my abs light turns on after like 3 minutes of dthe car being turned on.
Old Dec 25, 2006 | 07:44 PM
RTexasF's Avatar
Super Member
Default RE: Breaking Problems
With the brake pedal going to the floor I would suspect the master cylinder. I assume you have checked the fluid level?
Old Dec 25, 2006 | 11:15 PM
hondadude's Avatar
you can get the ABS code by using the service check connector, it is at the top of the passengerside kick panel kinda under the glove box. Link below. It will flash a two part code.
I would say from your description of the brake problem themaster cylinder is bad.
http://members.troublecodes.net/hond...ice%20conn.jpg
Old Jan 18, 2007 | 08:42 PM
thanks for your replies Im gonna buy the master cylinder for about 55 bucks and see if that fixes the pedal problem and the abs light
[align=left] [/align]
Old Jan 18, 2007 | 09:33 PM
hondadude's Avatar
Default RE: Braking Problems
I don't mean to be a doomsdayer, but the master cylinder replacement will probably fix the low Brake pedal, but it will not fix the ABS problem.
Old Jan 18, 2007 | 11:51 PM
poser_pilot6
If the brake fluid is low, that could be causing the ABS light to come on, I do believe. Of course, if you change out the master cylinder, wouldnt you have to bleed and refill the brake fluid anyway?
Old Jan 19, 2007 | 11:47 AM
deserthonda's Avatar
ORIGINAL: poser_pilot6
low fluid on the brake master will not make abs lite to come on,, abs system has its own reservoir
Old Jan 19, 2007 | 02:04 PM
Sinking pedal is classic for a bad master cylinder, but that won't fix the ABS problem.
Based on my Integra, probably the same system...
There's one shared warning circuit for handbrake & low brake fluid. This sets off the warning light on the dash, but it also feeds to the ABS controller. Drive around with low fluid or the handbrake set; you'll get code 2-1 from the ABS (along with the ABS warning lamp).
But... that means his handbrake warning lamp would also be on.
All we can do is guess until Miami reads his ABS error code.
Old Jan 19, 2007 | 08:26 PM
well I can hear my abs motor running when I turn my car on for about 2 3 minutes but then it stops and the light abs light comes on.
Old Jan 19, 2007 | 08:43 PM
hondadude's Avatar
pump overrun!!It's history, outta here, over with, kiss that baby good bye ! !
Does the ABS reservoir have any brake fluid in it?
By the way whats the code? LOL
