Broke valve cover stud 92 Accord DX 2.2L
Old Sep 26, 2011 | 10:32 PM
kturnerga's Avatar
Default Broke valve cover stud 92 Accord DX 2.2L
Hi
I was tightening the nuts on the valve cover of a 1992 Honda Accord DX 2.2L engine when I heard a snap instead of a nice sound from the torque wrench I was using. The stud broke! There is 1/4 to 1/8" left at the top.
After threatening to poke the wrench up Harbor Freight's a** and worrying about having to buy another engine block,etc I decided to crank up the vehicle. The stud was on the front passenger side. I did not see oil even at a high RPM. I wonder if I can drive this vehicle indefinitely if I keep an eye on the oil, if I can remove the stud with PB Blaster and Vise-Grips, or if I just need to take it to the mechanic and subject myself to his mercies?
I will NEVER buy another thing from Harbor Freight unless it is so childishly simple that it won't fail.
Old Sep 26, 2011 | 11:09 PM
I would remove the valve cover and use a pair of vice grips to remove the bolt as long as there is enough room to use vice grips. A new bolt from the dealership has to be less than $5.
It shouldn't take too long and it is a pretty cheap repair vs having an oil leak through the grommet or the valve cover gasket.
Old Sep 26, 2011 | 11:37 PM
kturnerga's Avatar
Since the valve cover gasket and spark plug hole gaskets of course haven't received much usage could I reuse them or is it best to go with new gaskets or RTV? Also would I have to drench the bolt stub in PB Lubricant and grunt and grunt as I extricate it?
Thanks
KT
Old Sep 27, 2011 | 12:07 AM
You can reuse the gaskets.
If the bolt wasn't cross-threaded, then it should only take one quick turn to break the bolt loose.
Old Sep 27, 2011 | 01:14 AM
bigpat's Avatar
Almost A Senior Member
If you can't get it to budge, use a torch on the snapped stud for a couple of seconds. The heat will transfer into the head and allow the stud to be removed. I did this on the exhaust port cover on my old Mercury 2 stroke outboard boat motor. Be very careful of where you put the flame and don't leave it on for over a few seconds.
Old Sep 27, 2011 | 07:40 AM
g22cd5's Avatar
Supper Moderator
you should be fine. TQ the rest of the VC studs to spec. I ran only 3 VC nuts on my cb for long time. Until I finally decided to replace it over a year later. Your VC gasket will be fine. Just bead a little bit of honda bond around the corners and your good to go. I recommend using Honda Bond over a generic RTV. Honda Bond won't eat up OEM seals and gaskets unlike some generic RTV brands.
Old Sep 27, 2011 | 08:29 PM
kturnerga's Avatar
I found that all but a stub of the threaded portion that sticks above the valve cover remains. The rest was in the nut. I saw a smoother, thicker portion I think I can twist out. I did put some RTV sensor safe silicone on parts of the VCG so I'll have to scrape it off first. Once I get the bolt and clean up the RTV I'll be ready freddy. To the Honda place I go for 90012-PT0-000 and 90013-PT0-000 in case it's one or the other.
DannyJdm
Dec 2, 2012 12:45 PM
adonus348
Nov 30, 2011 11:49 AM
g22cd5
Nov 5, 2010 01:29 AM
Mike 68
Dec 19, 2008 10:33 AM
bigspilv
May 6, 2007 03:20 AM
