burning smell
Old Dec 29, 2009 | 04:01 PM
00crossfire's Avatar
Default burning smell
hi i have a 96 accord that is making me sick because of the smell. it smells like a suffer smell but real strong and only happens when the car as been driven for about 2-3 str8, there is oil in it as well as anti freeze the car isnt overheating . i never heard about this problem ever. i need some opinions on this one. thank you
Old Dec 29, 2009 | 04:10 PM
That isnt the smell of rotten eggs by any chance is it ?
Old Dec 29, 2009 | 07:03 PM
91excoupe's Avatar
^^ I think i know where he's going with this... the catalytic converters can produce that smell with some age... usually right before they start plugging up...
Old Dec 29, 2009 | 07:04 PM
Yes it is, real bad to
Old Dec 29, 2009 | 07:08 PM
when you sayed the Cat. Converter has some age on it. about how many miles are you talking about, because my accord is running at 148000 miles its that pertty young, or is it just to much for the converter?
Old Dec 29, 2009 | 07:19 PM
91excoupe's Avatar
i've seen some cars start doing that as early as 60k, and some that have 200k and have never done it. Yes, 148k miles is pretty young for a Honda, but a cat is a cat, lol... they're really pretty much all the same...
Old Dec 29, 2009 | 07:23 PM
kris_loehr's Avatar
An engine miss could cause the cat to react and make a smell. Does the cat overheat it can turn red. The cat is pretty sensitive. I once cleaned the valve train off on an Accord with bakeclean then changed the oil and put the valve cover back on and it produced an awful smell that would not go away. The moisture coming off the exhaust was yellow.
Old Dec 29, 2009 | 07:29 PM
ok cool, this rings a bell, i remember my cat was burning or smoking, when i took a road trip. have u replace the cat., and if so did the smell go away
Old Dec 29, 2009 | 07:39 PM
whats up kris, to reply to ur response, my engine is fine it isnt misfiring it starts up without a problem for now lol, its just when there be a few times i drove it on D3 and the cat was steaming or smoking
Old Dec 29, 2009 | 09:29 PM
kris_loehr's Avatar
I have never seen a cat fail. It must happen as the material should fail over time, but the problems I have seen is the cat reacting to an engine miss. I would make sure you have no codes in the computer and/or running problems before replacing it. I had a car just about catch fire as it ran out of gas. It got a miss the cat overheated and floor started smoking as I took it around the block.
