Burning smell coming from vent???
Old May 13, 2005 | 08:36 PM
aang's Avatar
Default Burning smell coming from vent???
hi everyone, i have a 97 accord lx v6, it has around 80k miles. my question is if anyone in here ever came accross a strong burning smell coming from the vent which i'm sure came from under the hood. i get this smell when i make a u-turn or rough turning. i first notice this when i made a u to park, i thought it came from outside, but when i open my door no smell outside. I'm thinking maybe my power streering. anyone have any idea. thanks.
Old May 14, 2005 | 12:44 AM
habeel's Avatar
Default RE: Burning smell coming from vent???
only time i ever had that was when i fried the clutch, cant think why the power steering would give a burning smell!?
Old May 17, 2005 | 10:39 PM
Burn69's Avatar
Sounds like a clutch smell to me...does it still smell fromt the vent if you use recycled air button?
Old May 18, 2005 | 03:29 PM
aang's Avatar
now both of you (habeel & burn69) thinks that it's my clutch, u could be right. making a u-turn is the only time i have to change gear from forward to reverse then forward again. does that mean my clutch is getting ready to die?
no, if i have my recycle air on it does not smell.
Old May 18, 2005 | 04:55 PM
6thgen's Avatar
Could be...mine stunk like hell, when it went out.
Old May 18, 2005 | 08:42 PM
aang's Avatar
wow..that means money going out again, i just had my timing belt done. .how much do they usually cost to have the clutch done? thanks for everybodys help.
Old May 18, 2005 | 11:47 PM
Evlampius's Avatar
ORIGINAL: aang
if you're going to put in a clutch from the posts of those 2 guys - I will freak out
theres so many stuff that can smell - starting from the exaust leak..
....but what the heck - you wanna be a parts changer - can't help you... [:'(] [:'(] [:'(]
Old May 19, 2005 | 02:48 AM
aang's Avatar
no..no..no! i'm not going to just change my clutch just because of this forum. this is just a place to start investigating. i'm pretty sure it can be a lot of things like you said. the exhaust leak will probably smell like smoke rather than burning won't it?
Old May 19, 2005 | 12:24 PM
habeel's Avatar
i found that the clutch only gives the burnig smell when you dont balance the gas and clutch properly; giving lots of revs and riding the biting point tends to burn it out fast. and thats when i normally notice the smell; have you checked what revs you do when you pull away slowly or are turning - i tend to keep it to about 1000-1200 depending on the gradient of the road - i know some people that shoot up to 2000revs or over just pulling away slowly bringing the clutch up-
if your clutch control is good, it may not be the clutch thats burning (unless your doing launch starts- thatll kill the clutch good)
Old May 19, 2005 | 01:46 PM
aang's Avatar
hi habeel, i have an automatic transmission, will that give me the same problem?
