Busted seal?
Old Nov 20, 2019 | 05:05 PM
lydiatala's Avatar
Default Busted seal?
My 2001 Honda Accord 4cyl overheated. Turns out, it was just a hole in the hose. Stopped and people helped, but they noticed the oil was a little low and overfilled the oil without me knowing. Now there is coolant in the oil and bubbly sounds coming from the engine when the car is off. Sound like a busted head or a busted seal?
Old Nov 20, 2019 | 05:23 PM
plenum's Avatar
Rent out a block tester at oreillys. Check to see if they have it in stock, also you can rent out the block tester fluid (maybe) if they have that in stock as well. I would do an oil change as well if you don't know the levels.
How long was the car over heated? Did you shut it down immediately? I really hope it is not a bad head gasket.
I'm assuming they helped you fix the rubber hose and refilled the coolant?
Old Nov 21, 2019 | 09:24 AM
75Gremlin's Avatar
possibly a blown head gasket.
How to test:
JimRalphy
Aug 15, 2017 03:47 PM
whiskywaterwine
Jun 26, 2017 03:43 PM
Shooter 58
Apr 5, 2015 03:47 PM
swifity5
Aug 13, 2014 01:48 PM
msffletch
Apr 14, 2012 07:32 PM
