buzzing in reverse
Old Apr 12, 2009 | 10:42 AM
SQLServant
Default buzzing in reverse
Hi - New kid on the block here hoping to get a answer to why my car (2005 Honda Accord LX w/50,000 miles) is making a buzzing or whrrrring noise when the engine is cold and I put it in reverse. It stops temporarily if I brake to a complete stop but it re-starts once I continue in reverse. And when I shift into drive, the noise goes away. This behavior doesn't seem to happen when the engine is warm. I can't tell exactly where the buzzing is coming from. This has been happening for about the last 3 weeks. Hoping for some web-side assistance.
SQLServant
~50,000 miles
Old Apr 12, 2009 | 12:24 PM
finch13's Avatar
You could be hearing the straight cut reverse gears whining. Auto or manual transmission?
All forward gears are helical cut and make virtually no sound when they mesh, the reverse gears are straight cut (the first picture of a gear that comes to mind) and it makes a whining/whirring/buzzing sound when they're meshed.
Old Apr 12, 2009 | 01:27 PM
SQLServant
Default Re: buzzing in reverse
It's automatic transmission. To my ears and eyes (when I see bystanders' heads turn in my direction), the buzzing/whining sounds too loud for normal automobile operation.
SQLServant
~50,000 miles
Old Apr 13, 2009 | 08:22 AM
Have someone stand nearby to pinpoint the location of the sound. Is it possibly the brakes?
Old Apr 14, 2009 | 07:24 PM
SQLServant
Hi -- Had my wife stand next to the car while I backed out. She said it's definitely coming from the back of the car. Ideas?
SQLServant
~50,000 miles
Old Apr 15, 2009 | 06:51 AM
That pretty much rules out the tranny...
Rattling exhaust heatshield?
(Probably not 'cause that should keep making noise when the car stops.)
Rear brakes?
LX V-6 has rear disks & the inboard pads have a tab that makes noise when they wear out.
LX 4-cyl has drum brakes so they don't have that tab, but it's still something to check out?
Old Apr 15, 2009 | 06:27 PM
SQLServant
The rear brakes could be the culprit. I know that when I'm in reverse and I press the brakes, the buzzing or whining sounds squelched. So if it isn't the rear brakes, it's something very close to them. Thanks.
SQLServant
~50,000 miles
Old Apr 16, 2009 | 06:36 AM
Got a V-6 (rear disk brakes)? Or a 4-cyl (rear drums)?
Old Apr 21, 2009 | 05:10 PM
SQLServant
Hi -- Sorry for the late response. It's a V-6.
SQLServant
~50,000 miles
Old Apr 22, 2009 | 07:37 AM
Check whether the inboard pads are getting thin. There's metal tabs that are supposed to rub the rotors & make a screetching sound. When they first start to touch the rotor, the sound can be much different.
