a/c cooling issues
Old Oct 27, 2010 | 04:03 PM
truballer328's Avatar
Default a/c cooling issues
hey i have a few issues with the a/c, i have a 95 accord v6, when the a/c gets turned on it will start cool and then eventually start blowing ambient air. at night the a/c seems to work without a problem. also when i turn the **** to the highest setting #4 it shuts off..... any and all adive will be greatly appreciated.
Old Oct 27, 2010 | 07:57 PM
A common cause of your problem (cooling failing when fully warmed) is too large ac clutch plate gap. This prevents the magnetic field from exerting enough force to pull the plate closed. A good test when compressor is not engaging (if you can access clutch plate) is to rap the plate sharply w/ a stick while engine is running. If clutch immediately closes and compressor begins to cool, too large clutch gap is confirmed.
Fix may be problematic. You must access the clutch plate to remove (1-6mm, 10-mm socket size bolt), remove the clutch plate, remove one of the shims under the clutch plate (generally thinnest), and reinstall. Check clutch plate gap to meet your spec, usually around 0.020-inch, +/-0.005-inch. You may have to remove the compressor from it's mounting to access clutch w/o discharging and disconnecting ac hoses.
As always a Honda shop manual is your best guide.
Old Oct 28, 2010 | 08:59 AM
thank you very much will check as soon as i change these rotors and bearing...report back after thanks again
stavrich
Apr 18, 2015 05:59 AM
secritninja
Feb 5, 2014 01:54 AM
mandycae
Sep 5, 2012 06:35 PM
ebarrera661
Jul 30, 2010 12:53 PM
npinto97
Jul 13, 2010 04:43 AM
