A/C heat control unit button blink
Old Sep 4, 2013 | 11:37 PM
Santiago_909's Avatar
Default A/C heat control unit button blink
So i have a 1999 honda accord 4cyl and just recently the buttons of the A/C heater went out but before it did that they would just blink and then shut off completely! Anyone have that problem and how can it be fixed?
Old Sep 5, 2013 | 09:15 AM
Check fuses first. I assume this is manual heater/AC controls. Some diagnostics are available for ATC unit.
All lights going off indicates a common fault, damaged wire, or missing ground connection, or failed circuit board in the control unit.
You will need a shop manual to locate grounds and wires to inspect for damage. Check DIY forum, Online Manuals for a 98-02 manual or automanualsource.com for a download purchase for $22.
A used heater control panel can be found on ebay or car-part.com. I found them as low as $45 on car-part.
Old Sep 5, 2013 | 06:26 PM
keep_hope_alive's Avatar
there are shop manuals in this A/V section for our car for free download.
the bulbs can die and are cheap to replace. hondapartsdeals has them at dealer cost.
blinking is weird, especially if all of them did that. i think that would point to a bad connection at the controller.
Old Sep 6, 2013 | 01:02 AM
TexasHonda would you have any idea what fuses it would be? And thanks ill check it out.
Keep_hope_alive thanks
Old Sep 6, 2013 | 10:56 AM
I don't have a 98 Manual, but in 94 manual the control panel is powered from under-dash fuse box, fuse 8 (7.5A).
Power delivery path for LED's is through the dimming circuit. A faulty dimming circuit (on control panel) would disable mode switches. This is black box in 94 manual, so don't know if it's replaceable or repairable. Probably new control panel would be necessary.
good lcuk
Old Sep 6, 2013 | 06:59 PM
I have to ask....when the lights "blink" does the unit/system still work.......or when the lights go out, the ac (or whatever) stops working as well?
IMHO, pretty common that the PCB in the HVAC fails.....some replace, some add a jumper wire to the PCB and never have issues.
So again, when the lights "go out" does it stop working or is it just the lights?
Old Sep 7, 2013 | 07:41 AM
To answer the fuse question - #3 in the drivers under dash fuse box and #13 in the pass under dash fuse box.
Old Sep 7, 2013 | 11:24 AM
Poorman212 yes the unit stops working itll just start blowing alone while driving in the freeway or long distances. Icant seem to stop it cuz the buttons are off. And those are the fuses for the unit? Thanks
Old Sep 7, 2013 | 11:48 AM
Yes those are the fuses....
Do you have the "auto" hvac unit or the regular?
And here is a thread to read: https://www.hondaaccordforum.com/for...g-50944/page3/
Attached Thumbnails A/C heat control unit button blink-6th-gen-hvac-circuit.jpg
Old Sep 7, 2013 | 12:24 PM
Ill check the fuses and make sure theyre working.
Ihave the regular one no auto
Ill take a look at the thread thanks alot for the help.
