A/C Help
Old Jul 10, 2012 | 05:27 PM
mitchbill's Avatar
Default A/C Help
Hi all!
I'm new to forum but hope to use it as a resource for a couple small (hopefully) DIY projects.
Recently I swapped out my alternator in my 99 Accord which now works great, but in order to do so I disconnected what I now believe is the A/C hose to get it out. (not a good idea ) I'm not sure of the technical name but I pointed to it and the mechanic said "yep it was freon." I reattached it right away but immediately after the A/C stopped working.
So my main question is does it have to vacuumed out before it can be recharged (which I've heard isn't terribly hard and save the $200-300 from doing the alternator myself) because it was exposed to atmospheric elements?
Also is the vacuum something you can rent somewhere?
I appreciate any advice on the subject
Old Jul 10, 2012 | 06:22 PM
Michael Kozura's Avatar
It should not have to be vacuumed.... just get some freon and charge it..somewere under the hood there's the capacity on the system.
Mike Kozura
Old Jul 10, 2012 | 07:17 PM
mitchbill's Avatar
Mike Kozura
Guess he just wanted me to pony up a couple hundred bucks. He made it sound as if any exposure to air would bring moisture as well, and corrode it. And that would cost something like $3000 to fix. But it was literally less a minute.
Thanks for the input Mike.
Disagree w/ previous poster on vacuuming. If system is allowed to go to atmospheric pressure, you should replace the receiver/drier ($30) and vacuum for 1/2-3/4 hr to remove all moisture before charging through the low side.
You should also add 2 oz of pag oil (assuming that's whats in your system) to receiver/drier to replace that lost when you removed the hose and allowed system to explosively release.
I have heard you can rent a vacuum pump from Autozone but their website does not indicate this. Perhaps one of other auto parts.
You can buy your own AC manifold/gauge set and vacuum pump for around $150 from harbor freight and you're set for life for ac repair. AC repair is some of the easiest and most rewarding ($$) diy. I've been doing AC repair for 30 yrs now.
Old Jul 10, 2012 | 07:51 PM
Your welcome..... Old Texas is right.....but I'll bet it'll be fine...were ya from I can lend you my air vac and guages....from Harbor Freight....lol
Mike Kozura
Old Jul 11, 2012 | 07:55 AM
I guess it depends on how the refrigerant leaked out. When you disconnected the A/C line, it comes blowing out of the disconnected fitting. Once it STOPS blowing out OF EITHER SIDE, then air is able to get in. Air getting in is the bad thing, it would hurt the cooling performance of your AC.
If you re-connected the fitting while it was still blowing out, it would have been difficult to get the fitting lined up & start the threads. The refrigerant still blowing out will freeze your fingers.
If you waited and re-connected the fitting after it quit blowing out, then you most likely got air into the system.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
